Where's the dang drain plug/filter?
First post other than my "hello" in the new members area.
Trying to become a little more self sufficient and save a little money so I figured I'd start by doing my own oil/filter changes. Did my daughter's 2004 Mustang without too many problems. Then the fun began. Absolutely could not get the drain plug out on my 1998 Volvo wagon - some gorilla must have tightened it at the last oil change. Next came my wife's 2005 Santa Fe with the 2.7L V6. I must have spent 30 minutes crawling around under that thing with a flashlight and I simply could not find the drain plug or the oil filter. Am I a total moron (OK don't answer that) or do you have to remove that whole skid plate thing to get at anything underneath this model? The bargain basement lift I have didn't get the vehicle up very high so I was pretty limited to my movements but like I said, I pored over the belly of that beast with a flashlight! OK, I'm ready to take my abuse! :D |
RE: Where's the dang drain plug/filter?
The oil filter is on the side of the pan which faces the front of the car:
http://www.hmaservice.com/data/Passe...G/kfw3036a.gif The oil drain plug is located towards the rear of the pan (between bolts 7 and 8 in the picture below): http://www.hmaservice.com/data/Passe...G/edja970a.gif |
So you're saying I should be able to see both of these without removing anything else? Do they look weird or disguised or something? I swear I looked at every inch of the engine bottom with a flashlight and didn't see them!
You may have to remove a lower shield to see the pan. I know I have to on my Tucson.
Ahhh...now the plot thickens! I had a feeling I wasn't seeing everything. I guess I'm going to have to get a better jack to get the vehicle up higher in order to get that pan off and then be able to get at stuff.
Thanks! [sm=hail.gif] |
Hi
I am new to the site and was curious if anyone know if this would be the same chart for a 2008 Tucson with V6? My oil filter is very easy to access but not sure where the oil drain plug is? Any help would be greatly appreciated |
Drain plug is on the oil pan as seen in previous pics of 2.7 V6 seen above, need a 17mm wrench
Thanks! The oil filter is really easy to get too though. They must have changed something. I plan on putting 0W20 amsoil synthetic in it so it cuts the cost if I do it myself.
