Winsheild Washer Question
I just bought a 2010 Santa Fe. Only 34,850 miles on it. Everything works fine except the windshield washer???
It's full of fluid and the wipers work fine... Any ideas? Where is the fuse located??? Thanks... |
Do you have the owners manual? That info is listed there. I believe it is located in the engine compartment fuse box.
I have the owner's manual and have looked and it doesn't specify what fuse it uses... It would undoubtedly share a fuse with something else...
Maybe this weekend I'll start pulling fuses and checking that way... This car is only 5 years old and 34.9K miles so I wouldn't think it would be the pump??? |
Replaced the pump and problem solved :)
