won't start
My 2004 santa fe won't start turn key nothing.. The auto store told me it was my crank relay still won't start. Help please
Dead battery ? Good clean ground connect...
Probe solenoid wire for source voltage when key turned to "start" position --> bum solenoid/starter.. not very often, but maybe see 1 every other yr. |
what did you mean by this?
Originally Posted by sbr711
(Post 37167)
Probe solenoid wire for source voltage when key turned to "start" position --> bum solenoid/starter.. not very often, but maybe see 1 every other yr. Did you mean bum terminal wire going to starter or bum starter solenoid? I am trying to check that now, because it wont start at all now. |
Check the switch on the clutch that doesn't allows the starter to run unless the clutch is in.
Thank you. I checked the continunity previously and it registered but I then took the switch totally apart and filed down any rough parts on the copper and she works like a charm now! Again, thanx!
Nice work!
| All times are GMT -5. The time now is 01:29 AM. |
