01 sonata code P0500
Old Jan 30, 2008 | 05:04 PM
gussetgus's Avatar
Default 01 sonata code P0500
2.4 engine. Says vehicle speed sensor a malfunction. where is this sensor? bought the car a few weeks ago. so far the lot has sent it out to fix the crank sensor. when we picked it up the ck eng light came back on and now the speedo will not work. Took it back to the repair shop and they claim to have changed the speed sensor. but the speedo still wont work.any sugestions?
Old Jan 31, 2008 | 07:11 AM
Default RE: 01 sonata code P0500
P0500 = Vehicle Speed Sensor Malfunction
- The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
- There is a broken/frayed wire leading to the vehicle speed sensor
The simplest thing to do is to reset the code and see if it comes back.
Next, check all wiring and connectors that lead to the speed sensor. The location of the sensor depends on your vehicle. The sensor could be on the rear axle, transmission, or perhaps the wheel hub (brake) assembly.
If the wiring and connectors are OK, then check the voltage at the speed sensor.
If everything looks OK, replace the sensor.
Old Jan 31, 2008 | 08:37 AM
madindian1's Avatar
what actually happened is that whoever had the car replaced the right front axle and didn't noticed that the ring tone wheel on axle is not on it. that's probably why you're getting that code. not the sensor in the tranny, the one on the axle at the right front hub.
Old Jan 31, 2008 | 04:33 PM
gussetgus's Avatar
Ill have to pull the wheel on the right front. They changed the crank position sensor and you have to pull the right front wheel and splash guard off so maybe they knocked something off or broke a wire. The speedo was working when my son first had it it wasnt working after they fixed the crank pos sensor. thanks for the help everyone
Old Feb 3, 2008 | 07:24 AM
duke's Avatar
the speed sensor on the right front wheelis not for the speedo, but for the ECM for rough road sensing.
Old Feb 3, 2008 | 12:39 PM
madindian1's Avatar
why did they have to remove the front wheel to replace the cranksensor? oh this car is a four cylinder, well hope they fix it.
CptnNemo
Jan 2, 2013 09:49 PM
blackbox19
Aug 6, 2010 09:59 PM
geoffk
Dec 31, 2007 06:44 PM
DrunkCanuck
Aug 30, 2007 12:05 PM
slimone
Jul 28, 2005 12:51 AM
