'06 Sonata ATF change
Do I drain and then drop the pan to change the internal filter? Any flushing of the hoses or tubes to be done also?
3 Attachment(s)
Take it to the dealer to have it flushed on a machine. There is no servicable filter in teh trans. It's deep inside the trans. Also, Hyundai automatics REQUIRE SP-III fluid. Most non-dealer mechanics don't know that and will used the wrong fluid (which will damage your trans and void your warranty).
2006 Sonata Owners Manual: https://www.hyundaiforum.com/forum/a...1&d=1290173961 https://www.hyundaiforum.com/forum/a...1&d=1290173983 Hyundai TSB 10-AT-002: https://www.hyundaiforum.com/forum/a...1&d=1290174001 Cliffs Notes: - Only use Hyundai Approved transmission fluids - 2006 Sonata requires SP-III trans fluid - SP-IV and SP-III are NOT interchangeable - Non-approved transmission fluids will cause transmission damage - Damage caused by the use of non-approved transmission fluid is not covered by vehicle warranty |
Up here in Canada, this service runs about $370.00. Is the trans flush recommended or required?
Drain and fill will suffice.. We dont flush at our place
Originally Posted by sbr711
(Post 33507)
