07 sonata O2 sensor troubles?
My fiance has an 07 Sonata v6, yesterday she called me to say that the check engine light was flashing and the car was running rough. I went to her work, put some dry gas in it, and took it for a spin, engine light was on, but not flashing, car was running fine. I went to Advanced Auto Parts and had them check the code, they said it came back as a bad O2 sensor, unsure which, and car was mis-firing on cylinders 2 and 4. The guy couldn't tell me which sensor it was, but said it was probably one of the ones in one of the manidfolds.
Any ideas which sensor it is? when she was coming home the light was flashing and car running rough again, she let is sit for 20 minutes, and when started again light was off, and car was running like new...could the dry gas have cleaned any gunk off the malfunctioning sensor? |
Get a second opinion....
Originally Posted by johnnyg1105
(Post 25249)
(Post 25249)
Next fill up, I'd add a full can, (12 oz), of Sea Foam to the tank, (approx. $7.50), take the car home and disconnect the battery for about 20 minutes to clear any codes, and then see what happens as you then drive the car normally. |
| All times are GMT -5. The time now is 07:21 AM. |
