11 Sonata 2.4l multiple codes about Throttle position sensor
Recently purchased a 11 Sonata with 120k miles now check engine and traction light appears won't let me drive over 20mph I check it has multiple codes so I replaced the throttle body reset lights 2 weeks later same thing. Any Help? Codes: p0021 p0143 p1821 p2135 p2106 p0221 p2118 p2118
You have multiple codes. Most likely caused by one thing. I quickly looked up this:
What causes the P2118 code?These are the most common causes of the P2118 code:
Thanks I will check it out later thanks again
It sounds like the engine is going into "limp mode", to protect you , your vehicle and others.
I believe allegretto gave you good advice and agree with the suggestions he offered. |
