11 Sonata Flex Pipe Replacement
Old 08-23-2018, 11:23 AM
rromasko's Avatar
Default 11 Sonata Flex Pipe Replacement
The flex section is broken on the Sonata. It doesn't look like I have the room to weld in a new fleet section, at least not while on the vehicle. The new one comes with bolts/nuts to install, does anyone know if the manifold side is studs or bolts? They are rusted badly and don't even have threads anymore. I can see the studs ever coming out and may require a new converter/manifold.
Anyone replace this piece? Any tips?
Old 08-25-2018, 12:04 PM
If they are bolts you should be able to see the heads of the bolts.
gdoerre
10-12-2022 01:46 PM
Dandep
04-17-2018 04:16 PM
ironhorse99
01-22-2017 04:27 PM
gogiburn
01-26-2009 03:43 PM
drexellake
01-20-2009 08:27 AM
Quick Reply: 11 Sonata Flex Pipe Replacement
