-   -   1998 sonata (https://www.hyundaiforum.com/forum/hyundai-sonata-19/1998-sonata-466/)
cstonekk92 Sep 26, 2005 12:43 AM
1998 sonata
i have a problem with my sonata idleing. at first it started dying when i turned the airconditioner on at idle. now it dies as soon as you let off the gas. the problem with fixing it is it could be so many things and all those different things cost so freaking much you might as well get a new vehicle. so any suggestions as to what the problem could be would be helpful. also i had the transmission checked and the only code they could find was that cylinder 3 wasn't firing. the plugs and wires are good. any relation to the above problem and maybe suggestions on how to fix it. thanks
duke Sep 28, 2005 11:02 PM
RE: 1998 sonata
have a dealer check out the idle stepper-motor.
lorrie Nov 6, 2011 04:11 AM
check the power transmitter that fires the coils....that normally seems to be the issue..
