1999 Sonata GL stalls at when idle
Old Feb 10, 2006 | 12:08 AM
dwilcox's Avatar
Default 1999 Sonata GL stalls at when idle
Need some advice,
My Sonata GL 99 recently started stalling when idle and resembling a total loss of power (i.e. speedometer/internal lights/radio eventually die then I stall). Th odd thing is the battery is clearly in good shape because I can restart the car within a few minutes but again the same behaviour appears and dies within no time at all.
The check engine light is on but I can't seem to determine what the problem is...apparently on some models there was problems with MAF connectors shorting from engine vibration causing the car to stall - can this be the problem?
Anyways, please send me any ideas you got...I would rather diagnose and fix this issue as it does not appear to be a major electrical system fault.
Thanks for your suggestions.
Cheers,
DW
dadam
Nov 11, 2010 07:06 PM
tll66
Aug 5, 2010 11:28 AM
frank1234
Nov 24, 2008 08:56 PM
csecsys
Jan 7, 2008 08:04 AM
L2rocku2
Aug 3, 2005 12:57 PM
