2001 hyundia snonata 2.4 L spark plug question
Hey guys i have a 2001 Hyundia.. I dont have that much money and i need to change the plugs in my car..
Has anyone used Ap64's? I cant afford the NGK's is there a alternaitve plug that our cars like? |
RE: 2001 hyundia snonata 2.4 L spark plug question
You might consider either the Autolite ASPAP64 (which you may be asking about) or a Champion CHA3322. Both are platinum tipped plugs. I've had a tendency to use more Autolite plugs and have had good luck with them.
I went to walmart and the book says it takes a AP64 on the back says ap64dp2.. the number you said it doest match with kragens.. are you talking about a 2.4 L dohc? |
i bought the single plaitum ap64. should i return them and get the app?
The AP64s should work just fine, they simply will not last as long. You may only get 50,000 miles out of set instead of 100K.
while back i called autolite bec i had a 01 5.4 ford 4x4 . the reason for the call was that i heard a rumor that ford owns autolite.. The tech says that a auolite 103 plug is the same as the Motorcraft sp479. what the tech says is the single plaitum plug is a standard plug in a 01 5.4 and he said that its a 100,000 plug.. . He also says that the plugs are made side by side.. but with a diffrent name..
I heard rumors so i called a tech and watied 45mins on the phone.. I run ap104 in my other car i pulled them out running 50k and no gap reduction.. I was going to pull them at 60 k and check them again.. |
while back i called autolite bec i had a 01 5.4 ford 4x4 . the reason for the call was that i heard a rumor that ford owns autolite.. The tech says that a auolite 103 plug is the same as the Motorcraft sp479. what the tech says is the single plaitum plug is a standard plug in a 01 5.4 and he said that its a 100,000 plug.. . He also says that the plugs are made side by side.. but with a diffrent name.. |
kragen has the app on sell for $2.25 a plug..
but if they came with double paltiums why in the manual says to change them 60k? is autolite plugs better than champion ? |
