-   -   2001 - Location of obd port (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2001-location-obd-port-8706/)
Joemec Jul 22, 2010 08:27 AM
Searched under dash, but am unable to find.
Any hints?
Thanks,
Joe
NovaResource Jul 22, 2010 08:34 AM
Under the dash by the steering column.
Looks similar to this:
http://chevythunder.com/OBD_II_terminal.jpg
Joemec Jul 22, 2010 12:42 PM
Thank you for the response.
That is what I am unable to find.
Is it behind the dashboard?
Joemec Jul 27, 2010 08:52 PM
For those who may be searching for this answer:
As you face the front of the car, the obd port is in the upper right side corner under the steering wheel. It is almost completely behind the lower dashboard cover and can only be seen by shoving the accelerator with your head.
Plug in your scanner carefully, the port is not secured strongly.
Phillip W May 16, 2016 12:32 AM
Any hints?
Thanks,
Joe
For RHD (Australian) vehicles, the DLC is located to the right of the centre console area (and to the left of the steering column).
It is 'in the clear' though difficult to see attached (weakly) to the lower dashboard trim panel.
Don't get caught up (as I did) by thinking it was somewhere in the tangle of wiring near the fuse panel. It is on the other side of the steering column to that mess.
