2001 Radio removal?
Old Jan 15, 2009 | 06:26 PM
Avlis's Avatar
Default 2001 Radio removal?
Hi guys, I'm completely new to the forum, and after searching, I cannot find any help on removing the radio from my friends 2001 sonata. I have fiddled with it, but I don't wanna take too much apart, or break something while taking it apart the improper way. Could anyone throw me some kind of advice or help? Any help would be greatly appreciated.
Old Jan 15, 2009 | 06:37 PM
jsinton's Avatar
Banned
Default RE: 2001 Radio removal?
2001 > G 2.4 DOHC > Body Electrical System REMOVAL AND INSTALLATIONAUDIO REMOTE CONTROL[/align]a.Disconnect negative battery terminal.[/align]b.Loosen mounting screws and remove the audio remote control switch.[/align]c.Installation is the reverse order of preceding steps.[/align]AUDIO UNIT[/align]a.Disconnect battery negative terminal.[/align]b.Remove the console switch.[/align]c.Remove center facia panel and disconnect air temperature switch connector.[/align]d.Unscrew the audio mounting screws and remove the audio assembly from the mounting bracket.[/align]e.Installation is the reverse order of preceding steps.[/align] [/align] findme('); findme('); findme(');
Old Jan 15, 2009 | 06:42 PM
Avlis's Avatar
thanks, but I'm mostly having trouble removing the trim. Ive gotten as far as the shifter panel and coin tray.
Old Jan 15, 2009 | 07:10 PM
jsinton's Avatar
Banned
Without ever having seen one, I can tell you it doesn't say anything about removing the ashtray or shifter panel. First, take the neg battery cable off, then remove the console **** ( I assume it's the big *** on the radio). Then CAREFULLY pry off the fascia panel (look at the drawing) It has tabs on the top, so I assume you pry from the top. I assume the air temp switch control is also mounted to the fascia, so disconnect the cables from that. Once you get the fascia off, then just unscrew the radio unit and unhook the cables.
Does that make any sense?
zainecurtis
Apr 5, 2013 02:34 AM
flibottf
Jan 6, 2009 09:28 PM
jping
Sep 13, 2008 08:11 PM
santefe33908
Jun 29, 2008 08:58 PM
basicwizz
Jan 6, 2007 02:02 PM
