2001 sonata multiple engine misfire
Old Aug 25, 2009 | 05:36 PM
jim tjernlund's Avatar
Default 2001 sonata multiple engine misfire
having problem with multiple engine misfire,very bad when engine is cold,once it warms up it runs fine, any ideas?
Old Aug 25, 2009 | 09:01 PM
jsinton's Avatar
Banned
Could be all kinds of things. Did you do a code scan? Is there a check engine light?
Old Aug 26, 2009 | 03:43 AM
Default Reply
Was checked with a basic OBD scanner and pulled a 300 code which is multiple engine misfire. I'm thinking it must be a sensor or some computer related problem...any idea's?
Old Aug 26, 2009 | 07:37 AM
jsinton's Avatar
Banned
Could be a lot of things. I'd start by changing the plugs and wires.
From odb-codes.com:
A code P0300 may mean that one or more of the following has happened:
* Faulty spark plugs
or wires
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector(s)
* Burned exhaust valve
* Faulty catalytic converter(s)
* Stuck/blocked EGR valve / passages
* Faulty camshaft position sensor
* Defective computer
inyourface1650
Aug 23, 2011 12:06 AM
finsfan
Jun 12, 2007 05:16 PM
JLF
May 13, 2007 06:06 PM
rollerdawg
Aug 9, 2006 07:32 PM
