-   -   2001 sonata multiple engine misfire (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2001-sonata-multiple-engine-misfire-7043/)
jim tjernlund Aug 25, 2009 05:36 PM
having problem with multiple engine misfire,very bad when engine is cold,once it warms up it runs fine, any ideas?
jsinton Aug 25, 2009 09:01 PM
Could be all kinds of things. Did you do a code scan? Is there a check engine light?
jim tjernlund Aug 26, 2009 03:43 AM
Reply
Was checked with a basic OBD scanner and pulled a 300 code which is multiple engine misfire. I'm thinking it must be a sensor or some computer related problem...any idea's?
jsinton Aug 26, 2009 07:37 AM
Could be a lot of things. I'd start by changing the plugs and wires.
From odb-codes.com:
A code P0300 may mean that one or more of the following has happened:
* Faulty spark plugs
or wires
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector(s)
* Burned exhaust valve
* Faulty catalytic converter(s)
* Stuck/blocked EGR valve / passages
* Faulty camshaft position sensor
* Defective computer
