2001 Sonata - radio/clock/turn ind not working
Hi everyone,
Tried replacing the stock radio with a new radio in my 2001 Sonata...radio would not power up. Notice the contstant 12v power line was dead... as is the digital clock in the panel near the air vents. Also now my turn indicators are not working. Have checked the fuses and they seem ok (checked with continuity tester). The hazard lights work but not the turn indicators. Is it possible I blew a power fuse further up the line, say in the engine compartment ? Any ideas which fuses to look at ? I have checked AUDIO fuse but dont know what fuse supplies the constant (always on) 12v to the radio and the digital clock. Thats step one... then I need to find the fuse to the indicators and indicator relays. Help please ? Regards Kevin |
Do you have the owners manual for your vehicle?
If so, in there it will tell you which fuse protects what and it's location. |
Got it worked out. The plug was loose on the hazard switch. TY all.
