2002 hyundai sonata gls will not turn over?
Okay so this is what happens when I try to start it. Key is in ignition at accessory all lights work dash is on radio and interior lights work then I turn to next interval right before the turn to start and all dash lights are on to check bulbs ie check engine, oil pressure, etc. Then I turn to start car and nothing the accessories turn off to start car like normal the doors automatically lock but they unlock again right after by themself for some reason. And there is a faint clicking under the hood. It sounds like the solenoid trying to kick starter but I'm not sure. Some people have said that because the door locks are acting up it could be the security system locked my ignition switch? Need advice her car is stranded in a parking lot and no way to her work.
Try jump starting the battery
Jumper cables .. plus to plus and negative to engine ground. Low power can possibly make door locks act up? If that doesn't work then try hitting/tapping starter while someone tries to start engine |
| All times are GMT -5. The time now is 10:02 AM. |
