2002 Sonata MAF code P0171
Old Oct 25, 2010 | 06:37 PM
mikecorky's Avatar
Default 2002 Sonata MAF code P0171
I recently had a problem with my 2002, Sonata, 4cyl, DOHC, Autotrans. Car would stall if I unless I held down on the gas and even with constant pressure the idle would rev up and down. I replaced the MAF which solved the problem. Car runs great now, but I have a check engine light and the code is P0171 system too lean. I reset the code by disconnecting the battery and it came back after 50 or so miles. I was told it make take awhile for the computer to adjust to the new MAF. Any ideas?
Old Oct 25, 2010 | 07:18 PM
Make sure there are no air leaks in the intake tube between the MAF and the Throttle body.
capt1992
Apr 5, 2011 12:46 PM
sonata00
Feb 10, 2011 10:48 AM
blackbox19
Aug 6, 2010 09:59 PM
2001sonata
Oct 3, 2007 09:04 PM
