-   -   2002 Sonata MAF code P0171 (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2002-sonata-maf-code-p0171-9415/)
mikecorky Oct 25, 2010 06:37 PM
I recently had a problem with my 2002, Sonata, 4cyl, DOHC, Autotrans. Car would stall if I unless I held down on the gas and even with constant pressure the idle would rev up and down. I replaced the MAF which solved the problem. Car runs great now, but I have a check engine light and the code is P0171 system too lean. I reset the code by disconnecting the battery and it came back after 50 or so miles. I was told it make take awhile for the computer to adjust to the new MAF. Any ideas?
NovaResource Oct 25, 2010 07:18 PM
Make sure there are no air leaks in the intake tube between the MAF and the Throttle body.
