2002 sonata power steering problems
The power steering on my sonata is giving me fits.
A) I lose power when pulling into a parking spot, etc. B) The power steering pump is making a loud tapping noise c) There is a "whining noise" whenever the steering wheel is hot pointed straight. The car is a 2002 4 cylinder, manual transmission. What I have done: Replaced pump (4 times) each one makes tapping noise Replaced high pressure switch Replaced high pressure hose Replaced steering rack Replaced low pressure (return) hose Bled system by turning wheel lock to lock with car on lift, first with engine off, then with car on. New Power steering fluid New belt Any body ever have any experience with this? Have any ideas?:confused: |
what type of fluid are you using? if the power steering pumps were remans i know they recommend certain brands of fluid to ensure quality fluid. if all your parts are genuine hyundai i know their are different fluid requirements.
also you might want to try a power steering flush! mike |
Originally Posted by ottoX
(Post 25276)
Have any ideas?
Thanks for the input. I am using regular over the counter power steering fluid - there is a lot of controversy as to what fluid to use, as the PSF3 Hyundai recommends doesn't actually seem to exist. I may have to try Dexron 3 -automatic trans fluid as that is what about half the posts regarding fluid seem to recomend.
As far as the screen and flush - Did that while assembling various parts. Took the reservoir off and cleaned it and the screen, which was actually pretty clean. |
1 Attachment(s)
(Post 25337)
Good luck. |
