-   -   2003 Hyundai Sonata Fog Light HID Conversion (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2003-hyundai-sonata-fog-light-hid-conversion-9296/)
Eppsilan Oct 11, 2010 10:19 PM
I recently bought a HID kit for my fogs (9006). But the problem is, as soon as i plugged them in and attempted to turn them on, I blew a fuse. Does anyone have any suggestions on what I could do to get my Fogs working?
I have HIDs in my Lo's and my Hi's and they work just fine. But the Fogs are the problem....
I have a full HID kit from Xentec, (Ballast, Harness, Bulbs, Etc)
Help Anyone?
NovaResource Oct 12, 2010 07:14 AM
I'd contact the people at Xentec.
rallyman Oct 12, 2010 12:55 PM
Re-check all your connections to make sure they are all tight and correct. You must have a short somewhere due to the installation of the kit if the fogs were working properly before. Otherwise, as stated, contact the seller as there may be a defect in the kit components.
Eppsilan Oct 13, 2010 06:06 AM
I hooked up the fogs to my Lo-Beams, and they work just fine. Im pretty sure that its all hooked up correctly.
Is it possible that its just producing too much power, and the stock harness / other stuff, just cannot handle it?
I will attempt to contact Xentec, but I dont know if they will be able to help
rallyman Oct 13, 2010 10:31 AM
If you are sure that all connections were made correctly including polarity then I guess you might want to consider getting a relay harness for the HID kit which will power it directly off the battery and use the factory wiring only to turn on and off.
Eppsilan Oct 14, 2010 04:41 AM
Good idea man, I will grab one of those, and attempt to get it working.
