-   -   2003 sonata gl v6 need help with 2 things (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2003-sonata-gl-v6-need-help-2-things-8003/)
surfguy17 Mar 9, 2010 03:55 PM
hey all im new to the forums and to Hyundai :) i bought a 2003 sonata GL V6 with 71 831kms a couple weeks back (good deal couldnt pass up). i have a few questions about it. one is a problem and the other is a question.
1) is there a way to make the keyless remotes beep when the door is locked/unlocked? has the factory keyless entry in it.
2) i am having a problem with the stock radio/cd player. it actually started this week. what happens is the FM stations dont work (just produces static) but the AM stations work fine. is there a way to fix this?
thanks for any input much appreciated :)
sbr711 Mar 9, 2010 05:49 PM
Not that I know of... user options is typically found in the BCM (Body Control Module),,, that vehicle has no BCM
Send it out for repair, but in house we use use the "Float" radios (reman exchange units), and they are pricey.. :(
Usually I see the radios turn on by themself... Key on, thump the top of dash and see if radio turns on..
surfguy17 Mar 9, 2010 10:00 PM
the AM stations work on the radio its only the FM stations that have stopped working (just makes that static noise) tried removing the fuse and putting it back after 30 sec. but it didnt work.
