2004 Sonata V6
My 2004 Sonata V6 has 60K miles, suddently it has no power as if maybe a fuel problem. 1. Where is the fuel filter? 2. Can I change the fuel pump with out removing the gas tank? 3. Has any body had this problem? 4. What should I do? 5. What else could it be? It is not drivable as is!
Originally Posted by Tom Dugan
(Post 27394)
Is the engine BLAAAHHHHHHHH when you accell, or does it shake and bump with the MIL flashing at you ? 1. Where is the fuel filter? In the fuel pump module in the fuel tank... 2. Can I change the fuel pump with out removing the gas tank? Yes, but I do not think this is the problem.. 3. Has any body had this problem? 4. What should I do? Get it repaired, is the MIL illuminated ?? Is it solid, or flashing ? If flashing, get it repaired before you kill the cat(s). 5. What else could it be? It is not drivable as is! 60,000, I would be looking for plugs and wires if it is indeed mis-firing,,, get it scanned and se what you have to deal with. |
Yes, BLAAAHHHHHHHH when I accellerate
I found the fuel pump access panel in the trunk. I also found a mouse nest under the intake plastic cover, I have not found chewed wires. Today when I tried again the trouble shoot the problem, the problem was gone. I don't know what the changed sence last night when it did'nt have any power at all. just BLAAAHHHHHHHH when I accellerate. Today lots of power and no issue. My thinking is maybe the mouse chewed a wire somewhere that is shorting intermittenly. Or the mouse nest was wet from rain the night before, causing the injectors to short out. If it was a fuel pump or a fuel filter would the problem just go away? I know i'm grasping for ideas, but eager to read any sugestions. if I dont solve the problem in will come back at the worst timming. If you have an idea, i'm interested. |
