2006 Hyundai Sonata GLS 3.3L engine
I have a 2006 Sonata and pulled the following error codes P1295/P2135/p2106. The car starts, but most times it goes directly into the limp mode. My problem seems to be covered in TSB 09-FL-003-4. does anyone have a copy of this? It also looks like I may have to replace the electronic throttle control and/or the throttle position sensor. Does anyone have step by step replacement directions for these parts and the part numbers?
TSB 10-FL-010 replaces 09-FL-003. The PDF is stoo large to post here so check the email that you registered with for a PDF copy of the TSB. Hope that helps.
| All times are GMT -5. The time now is 09:54 AM. |
