2007 sonata 2.4L A/C compressor bypass
1 Attachment(s)
Found a way to bypass the a/c compressor on the 2007 sonata 2.4L. You'll need to use a 80.5" belt using this diagram and it will get you out of a jam until you can get the compressor fixed. Easiest way to get the belt on is to save the power steering pump pulley last, with the belt on and the tensioner all the way back just roll the belt on the power steering pulley and your good to go just no A/C.
Attachment 1524 |
How is your visibility during cold or wet days?
