Radiator Fan not working 2004 Sonata
Old 10-29-2018, 09:42 PM
earlybird's Avatar
Default Radiator Fan not working 2004 Sonata
My cooling fan not coming on, I have checked all the fuses and swapped around relays but same problem.
If I short the relay contacts on the radiator fan low the fan spins
If I disconnect the wires to the temperature sensor the fan does not come on which I believe it should correct me if I am wrong.
If I remove the diode that seems to connect the ECM signal to the relay and use a test light probe to connect it to the negative battery terminal the fan comes on.
I am thinking that the ECM is not sending a signal to the relay to turn on the fan.
Can someone guide me as to what to look for going forward.
Thanks.
wagoss
01-10-2015 07:35 PM
JimBob6
04-04-2010 09:39 PM
jasons_accent
12-07-2009 12:29 AM
rico
09-27-2008 12:07 PM
Irish
06-06-2006 02:24 AM
Quick Reply: Radiator Fan not working 2004 Sonata
