2007 Sonata possable problem with MAF/MIT Sensor. My Meter's code is PO105 #11.HELP?
2007 Sonata possable problem with MAF/MIT Sensor. My Meter's code is PO105 #11.HELP? CHILTON'S book does not show a PO105, Only PO101 through PO103 and then goes on with PO106 and on???
Very hard starting is the problem. Have also just had a dead battery. Car has been siting, un-run for over 3 mounts??? |
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
Possible causes- Faulty Manifold Absolute Pressure sensor - Manifold Absolute Pressure harness is open or shorted - Manifold Absolute Pressure sensor circuit poor electrical connection - Faulty Engine Control Module (ECM) |
thanks, but where is the map located???? I can't locate it
Vehicle uses a mass airflow sensor. Intake air temp sensor is built into the mass airflow sensor and not serviceable separately
thanks, but what does the sub number 11 mean??? ie My Meter's code is PO105 #11
Originally Posted by Jimintexas
(Post 48578)
Jimintexas,
MAP sensor location is item 4 on diagram. Believe location to be the same for 2.4 and 3.3 V6, but unsure. OEM Hyundai part number is 39300-38200 (for both 2007 Hyundai 2.4 & 3.3 engines). http://repairguide.autozone.com/znet...3f80e41ea4.gif |
