2007 Sonata which Tire Size to Buy
Hello All,
Thank you very much for your continued support, I have another question for the forum. I have a 2007 Hyundai Sonata 2.4 liter with aluminum alloy wheels which has Michelin 215/55 R17 tries. I am located in California and I am looking to buy just regular tires for my Sonata however my question is that what size should I buy? There are six variants available 1. 215/50 R17 2. 215/55 R17 3. 215/60 R17 4. 215/65 R17 5. 225/50 R17 6. 225/55 R17 7. 225/60 R17 8. 225/65 R17 I would understand that 215 and 225 is the width of the tire but if I go for a wider tire will it interfere with my wheel arches of my car? Also if I stick with 215 tires then can I opt for either 50/55/60/65. My colleague indicated to me that the engine life of the car increases if the tires have a larger diameter namely 215/65/R17, he also indicated between 215/65/R17 and 215/50 R17 it will be better to opt for 215/65/R17 as the engine will be spinning at a lower RPM for the same speed which in turn will marginally affect engine life and mileage. He did say that there will be a speedometer error which will have to be compensated Is there any brand of tires which is better than the rest? Any advise will help me out. Regards Veneet |
Your original 215/55 R17 tries are 26.3" tall.
215/50 R17 tires are 25.5" tall and will cause an speedometer error of 3.0%. (Unacceptable) 215/60 R17 tires are 27.2" tall and will cause an speedometer error of 3.3%. (Unacceptable) 215/65 R17 tires are 28.0" tall and will cause an speedometer error of 6.7%. (Unacceptable) 225/50 R17 tires are 25.9" tall and will cause an speedometer error of 1.5%. (Acceptable) 225/55 R17 tires are 26.8" tall and will cause an speedometer error of 1.8%. (Acceptable) 225/60 R17 tires are 27.6" tall and will cause an speedometer error of 5.2%. (Unacceptable) 225/65 R17 tires are 28.5" tall and will cause an speedometer error of 8.3%. (Unacceptable) Personally, I would go with the 225/55 R17 tires. As far as brand, I've always had good experience with Kumho tires. |
Originally Posted by Veneetraj
(Post 20636)
My colleague indicated to me that the engine life of the car increases if the tires have a larger diameter namely 215/65/R17, he also indicated between 215/65/R17 and 215/50 R17 it will be better to opt for 215/65/R17 as the engine will be spinning at a lower RPM for the same speed which in turn will marginally affect engine life and mileage. He did say that there will be a speedometer error which will have to be compensated Is there any brand of tires which is better than the rest? Any advise will help me out. Regards Veneet I recommend buying the stock tires as this is the tire that was designed for the car. It's a crap shoot to second guess what might be a better size. Nova is right, Kumho is a great balance of price and performance. The best Kumho tire is excellent, even for my Lexus. You could buy Michelins, but they cost 33% more and are not any better. Explore your tire options on tirerack.com, the largest seller of tires in the world. |
Hello Nova and Jsinton,
Thank you very much for your responses. will stick to the origninal size of what I currently have. Regards Veneet |
| All times are GMT -5. The time now is 08:26 AM. |
