-   -   2008 Sonata ESC turns it self off (https://www.hyundaiforum.com/forum/hyundai-sonata-19/2008-sonata-esc-turns-self-off-12541/)
Chip Wise Apr 15, 2012 06:55 AM
My 08 Sonata has been turning the ESC off by it self. As i am driving i will notice the ESC light come on it i toggle the switch nothing happens but when i turn the car off and back on it clears. This has happened about 6 to 8 times over the last month. Has any one had this happen any ideas what might be causing it to happen. I have looked for recalls but don't see anything.
Thanks.
NovaResource Apr 15, 2012 09:29 PM
Something is wrong with it. A bad sensor or something. 5 year warranty: covered.
elkarshofy Apr 16, 2012 03:58 AM
Do brake lamps work? Try to check The Brake Light Switch because it's COMMON PROBLEM OF hyundai and try to check ESC fuse too.
onelowvoltage Jul 5, 2012 11:33 PM
I just had the same problem with my 2008 Sonata. It looks like the brake light switch is cheap and easy to replace. Hopefully, mine has over 60K on it. But I will have to check the next time this happens to verify that the brake lights are out. Or that's how I understand it. Anybody know if the brake lights could still work and yet the switch is still the problem?
JimF Aug 3, 2012 08:42 AM
My 2010 Sonata (14000 Miles) ESC light goes on and the car goes into "Limp" mode (Won't accelerate, creeps along at 20 mph.) Towed into dealer 4 times in July- no relief but plenty of stories. Contacted Hyundai talked Vincent, Alexander, Lora, Corey et. al. All would help. Was told their regional office would call me. That 2 days ago. (I think their regional office is the waste paper basket.)
Question is: what recourse do you have if a dealer svc. dept. decides a repair is too costly??
NovaResource Aug 3, 2012 08:46 AM
It's still covered under the 5y/60k mile warranty. If this dealer is giving you problems, find a different one with a better service department.
JimF Aug 3, 2012 09:20 AM
What happened to Lora, Alexander, et. al. at Hyundai Corp. and the helpful "regional office"??? Shouldn't they help a situation like this, or just fluff it off?
NovaResource Aug 3, 2012 09:36 AM
I don't know what you are talking about. If the service department of your dealer stinks, go to a different dealer.
