2009 4 cyl.TSB's
i have been trying to get on to hma service's site for too long and its just not happening --yes i did go through internet explorer --anyway can someone tell what TSB's are out on the 09 sonata 4cyl thanks -
Did you manage to create an account? Can you login?
If so, just click "shop", then "service information", then TSB. It looks like it won't work, but give it a shot. There's too many TSBs to give you a list. |
Originally Posted by boilerman
(Post 21882)
i have been trying to get on to hma service's site for too long and its just not happening --yes i did go through internet explorer --anyway can someone tell what tsb's are out on the 09 sonata 4cyl thanks -
08-AT-002 AUTOMATIC TRANSMISSION SHIFT KNOB REPLACEMENT PROCEDURE 08-be-002 ipodŽ cable assembly 08-SS-004 DIAGNOSIS AND CORRECTION OF VEHICLE PULL 08-BD-007 2006-2009 SONATA MANUAL DRIVER’S SEAT HEIGHT ADJUSTER PIVOT LUBRICATION PROCEDURE 08-SS-008 ALIGNMENT SPECIFICATIONS - 2009 MY PASSENGER VEHICLES 08-bd-003 2009 my sonata exterior color codes 08-bd-015 2009 sonata body dimensions 08-bd-017 2009 my sonata exterior color codes 09-bd-002 2009 sonata driver seat cover loose 09-BD-003 ALUMINUM WHEEL CLEANING AND MAINTENANCE 09-EM-001 UNNECESSARY ENGINE FLUSH SERVICES 09-AT-002 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUES 09-AT-006 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE 09-AT-007 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM 09-AT-008 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE 09-be-002 occupant classification system - service reset procedure 09-be-004 navigation map software update 09-EM-002 CVVT OIL CONTROL VALVE INSPECTION |
