2009 sonata
OK. My car is hanging out of the garage jacked up. I'm going to bed now. Does anyone have experience with removing and replacing the rear wheel bearing on this model. I have the new assembly and just removed the old assembly, but it came off with the entire backing plate which now I can't separate from the hub flange. You tube has nothing.....anyone can help, it would be appreciated.
the plate is held in place by the same 4 screws as the bearing carrier so 'naturally' it will come off. But you should be able to separate it from the bearing. Likely it's just rusted together.
Originally Posted by e3tom
(Post 51290)
