Wandering direction question 2005 4 cyl
Old 11-11-2009, 03:53 PM
g1e2n3d4r5o6n7's Avatar
Default Wandering direction question 2005 4 cyl
96000km car, seem that the car has to be controlled lightly straight forward ,tends to follow road unevenness.....hard to describe because not really noticable unless you have a long stretch with it....had it aligned to spec, changed tires,power fluid , still this weird behavior.....like driving these old car with worn out direction gears.....may be I'm to fussy or gettoing old....
Old 11-14-2009, 02:48 PM
Jim in Indy's Avatar
Have you recently replaced or rotated, your tires? If the local alignment shop says everything is 'tight', within specs & no abnormal tire wear, a slight bit of additional toe-in can help.... but only a slight bit, as to much can increase outside wear on the front tires.
ramirez32385
05-03-2014 02:51 PM
JoeMario
05-27-2009 02:04 PM
JohnRossitter
11-21-2007 07:33 PM
finsfan
06-12-2007 05:16 PM
spf150
02-11-2007 03:43 PM
Quick Reply: Wandering direction question 2005 4 cyl
