2010 Sonata rear window defroster does not work
Old Nov 11, 2020 | 01:59 PM
Rob Carneado's Avatar
Default 2010 Sonata rear window defroster does not work
So my rear defroster does not work. When I push the button the led does light up but it is orange...not green. I can also hear a click when I toggle the switch near the fuse box. I looked for fuses for the defroster but can't find one specific. Is it a relay I'm missing? Please help. Thank you.
Old Nov 13, 2020 | 07:39 AM
If you have the vehicle owners manual, it should , in the maintenance section, tell you which fuse/circuit breaker and relay are to protect the rear defroster system.
Old Nov 13, 2020 | 03:21 PM
avisitor's Avatar
Are you getting battery voltage at the rear defroster??
If you are not then look for fuses
If you are then rear defroster is faulty
Check for resistance and look for broken lines
edwardp
Feb 3, 2022 06:33 PM
yenoocpb
Sep 5, 2012 12:26 PM
wxkidmrc24
Jan 23, 2009 07:11 AM
njf207
Oct 29, 2007 11:44 AM
padiscus
Jul 20, 2007 01:19 PM
