2010 sonata wiring guide
does this exist? im not happy with the factory stereo, and wanted to replace it with anoter double din radio. problem is that i cant seem to find one online, and crutchfield states that they dont have specific installation instructions for a 2010. any help would be appreciated
Sign up for FREE account at www.hmaservice.com , and look at site requirements and them.
From the select ETM, select vehicle by model, year, engine from drop down boxes, and run. |
The information provided by Sbr711 will get you to the wiring schmatics, but will not explain how to remove the radio. Here are those instructions.
SONATA(NF) >2010 > G 2.4 DOHC > Body Electrical System > Audio > Audio Unit > Repair procedures Replacement 1.Disconnect the negative (-) battery terminal. 2.Remove the console under cover (B). http://www.hmaservice.com/data/Passe...snfbe9156d.gif 3.Remove the side garnish(A). (Refer to the Body group - crash pad) http://www.hmaservice.com/data/Passe...snfbe9017d.gif 4.Remove the center garnish(A). http://www.hmaservice.com/data/Passe...snfbe9018d.gif 5.Remove the crash pad center facia panel(A). http://www.hmaservice.com/data/Passe...snfbe8132n.gif 6.Remove the clock connector(A) and heater control unit connector(B). http://www.hmaservice.com/data/Passe...snfbe9021d.gif http://www.hmaservice.com/data/Passe...snfbe9022d.gif 7.Remove the mounting screws then remove the audio unit (A). http://www.hmaservice.com/data/Passe...snfbe9023d.gif 8.Remove the the audio unit connectors and cables(A). http://www.hmaservice.com/data/Passe...snfbe9024d.gif 9.Installation is the reverse of removal. |
Where did you get those instructions? Thanks.
From the hmaservice.com site.
