2011 hyundai sonata will not start
Old 05-20-2018, 01:53 PM
Kiozsa Spann's Avatar
Default 2011 hyundai sonata will not start
I have a 2011 hyundai sonata that just will not crank. The P like does not display on the dash to indicate that the car is in park. All fuses have been checked. I'm just baffled at what could be going on. Can anyone explain what may be the problem?
Old 05-21-2018, 04:39 PM
avisitor's Avatar
There is a park/neutral safety switch that keeps the starter from cranking the engine if it is not in park or neutral
This prevents the car from moving unintentionally
The fact that it does not indicate the park position means that it isn't registering
You can try neutral to see if that will work.
Remember that it must register or indicate it is in neutral.
You may have to reset the position of the switch or replace it
Can't see it from here
You need to do some testing
Old 07-18-2018, 11:05 PM
Tubocuv's Avatar
Default Try this
If it is not asking for the key there is a switch under the brake pedal that might need to be replaced
gorillum
12-12-2020 05:38 AM
gmelit57
07-26-2013 12:32 PM
MLynch
02-15-2011 03:06 PM
Brant
11-14-2006 01:09 PM
clueless
09-18-2006 04:58 PM
Quick Reply: 2011 hyundai sonata will not start
