4G Sonata radio, clock, and keyless entry... fixed
Old Jan 1, 2008 | 11:33 AM
awsnap's Avatar
Default 4G Sonata radio, clock, and keyless entry... fixed
Ok, yes, I have an hidden motive. I'm a car audio installer, BUT my wife does have an '07 so I will be around otherwise. The MAIN reason for this post is I have a customer that I just put an Alpine IVA-W205 into his Sonata pulling out the Infinity deck, amp, and even the XM tuner. I also had the door panels off to put in all new speakers.
Now the keyless entry system does work! I'm not sure if it's integrated into the radio or if I did something when I pulled the door panels off but I can't figure it out. Also, his trunk pop on the door only works when the car is on. Odd, I haven't checked my wifes yet but I think it works anytime.... Also, I noticed that the clock in the car does not work. WTF. I am a very accomplished installer, but this car is kooky.
Anyone have any insight?!?!
Old Jan 2, 2008 | 07:45 AM
madindian1's Avatar
Default RE: 4G Sonata radios, clock, and keyless entry...
CHECK POWER CONNECTOR FUSE IN PASSENGER COMPARTMENT FUSE BOX.
Old Jan 2, 2008 | 09:22 AM
awsnap's Avatar
DRRR.. Yeah, I'll try that. I'm starting to think like the guys at the stealership, blaming everything on something changed in the car.....
You think that the clock and keyless are both tied into the same fuse?
Old Jan 2, 2008 | 08:20 PM
madindian1's Avatar
well they are tied in the power connector and the trunk switch only works when the key is on( a sign that the power connector is not in or fuse blown) heyI work forA STEALERSHIP
Old Jan 4, 2008 | 10:20 AM
awsnap's Avatar
OK, so the car is back in the bay right now and I just fixed it. Here's the deal. The clock didn't work ever, the interior lights and trunk light didn't work, the keyless didn't work, and the door locks and trunk pop only worked when the car was on.
Fuse 15amp MEMORY located with the AUDIO fuse in the protective yellow clippy thing. DO NOT TRY THIS AT HOME***** so I just swapped a 20 amper in and it's all good. ****
Old Jan 4, 2008 | 11:12 AM
madindian1's Avatar
WOW GOOD JOB
Monfortae
Mar 11, 2017 11:04 AM
brad13
Jun 11, 2011 06:03 PM
kutupla
Mar 29, 2011 07:43 AM
hdsalinas
Feb 1, 2011 09:46 PM
dovie
Mar 20, 2007 12:34 PM
