-   -   4G Sonata radio, clock, and keyless entry... fixed (https://www.hyundaiforum.com/forum/hyundai-sonata-19/4g-sonata-radio-clock-keyless-entry-fixed-3580/)
awsnap Jan 1, 2008 11:33 AM
Ok, yes, I have an hidden motive. I'm a car audio installer, BUT my wife does have an '07 so I will be around otherwise. The MAIN reason for this post is I have a customer that I just put an Alpine IVA-W205 into his Sonata pulling out the Infinity deck, amp, and even the XM tuner. I also had the door panels off to put in all new speakers.
Now the keyless entry system does work! I'm not sure if it's integrated into the radio or if I did something when I pulled the door panels off but I can't figure it out. Also, his trunk pop on the door only works when the car is on. Odd, I haven't checked my wifes yet but I think it works anytime.... Also, I noticed that the clock in the car does not work. WTF. I am a very accomplished installer, but this car is kooky.
Anyone have any insight?!?!
madindian1 Jan 2, 2008 07:45 AM
RE: 4G Sonata radios, clock, and keyless entry...
CHECK POWER CONNECTOR FUSE IN PASSENGER COMPARTMENT FUSE BOX.
awsnap Jan 2, 2008 09:22 AM
DRRR.. Yeah, I'll try that. I'm starting to think like the guys at the stealership, blaming everything on something changed in the car.....
You think that the clock and keyless are both tied into the same fuse?
madindian1 Jan 2, 2008 08:20 PM
well they are tied in the power connector and the trunk switch only works when the key is on( a sign that the power connector is not in or fuse blown) heyI work forA STEALERSHIPhttps://www.hyundaiforum.com/micons/m9.gif
awsnap Jan 4, 2008 10:20 AM
OK, so the car is back in the bay right now and I just fixed it. Here's the deal. The clock didn't work ever, the interior lights and trunk light didn't work, the keyless didn't work, and the door locks and trunk pop only worked when the car was on.
Fuse 15amp MEMORY located with the AUDIO fuse in the protective yellow clippy thing. DO NOT TRY THIS AT HOME***** so I just swapped a 20 amper in and it's all good. ****
madindian1 Jan 4, 2008 11:12 AM
WOW GOOD JOBhttps://www.hyundaiforum.com/micons/m9.gif
