94 sonata=battery drain=no idle
Old 11-26-2004, 05:30 PM
bharat's Avatar
Default 94 sonata=battery drain=no idle
<IMG src=smileys/smiley6.gif border="0">hi i have a sonata 1994 model 2.00 cdi with 100k miles on clock</P>
ye cars been really good up till now</P>
3mths ago it started with no idle but i can live with that by just stepping up on the gas to bring the engin rev up</P>
more worrying lately its got a battery drain problem(no warning lights on dashboard=normal lights) =have had the alternator checked out at an auto elecplace who says its perfect=not wrong so i guessed it must be the battery</P>
fitted a new battery but the problems still there it just drains out after 4 days or about 100miles</P>
its all factory torqued and no ones played with ityet, am now lost to see what the problem is</P>
any help and ideas please</P>
since posting this i have now got a meter to tell me if the charging current is on or not. well it charges purfect when engine is cold and as the engine heats up say in 2 miles the charge lighton the gadget drops out and drains the battery. let the engine cool down and the whole thing starts again ie charging when cold and when hot in 3 miles it drains</P>
any replies would help</P>
</P><edited><editID>bharat</editID><editDate>38318.5226851852</editDate></edited>
Old 04-25-2016, 01:39 AM
otis66's Avatar
Check the belt. A worn belt will slip just enough to not charge the battery. When you first start your car everything can be fine. Once the car warms up or you start driving down the road the belt starts to slip. Also, sometimes the belt is okay when you are at idle and testing the charging system but the min you start driving down the road the belt starts to slip. A slipping belt will not turn the alt fast enough discharging the battery. Also when you test the charging system you should turn on all of the acceoris heat, lights ac etc to put a full load on the alt. Also check the belt pulley.
ulek
03-17-2006 06:24 PM
Fernholz2
12-09-2005 12:25 AM
bek0r
12-07-2005 04:55 PM
neta
01-21-2005 12:23 AM
amckee2
09-14-2004 02:44 PM
Quick Reply: 94 sonata=battery drain=no idle
