ABS/ESC warning lamps
FYI: The ABS/ESC warning lampslit up on my 06 Sonata. Also, the brake lights would not come on. Took it to the dealer expecting $$$$. Turned out to be the brake switch. Fixed under warranty in about 10 minutes. Why it istied together, who knows? But I post this in case you have a similar situation. :eek:
RE: ABS/ESC warning lamps
Why it is tied together, who knows? |
Question - does my 2007 Sonata have a function that alerts me when the brake pads are getting low and need to be replaced before the rotors get affected? I've heard of some cars having this, but I'm not sure if this car does.
Actually, yes it does. But it's not an electronic monitor that illuminates a light in the dash. Each brake pad has a small piece of metal that will come in contact with the rotor when the pads are low. The metal tab will cause a squealing sound when driving (not while braking). If you hear that squealing, it's time to check your pads.
Also, as the pads wear, less brake fluid returns to the master cylinder. So when the master cylinder is low on fluid, it's a good indication that the pads are worn. DO NOT ADD FLUID! Check the pads first and replace any worn pads. If you add fluid first and then try to replace the pads, you will have to remove fluid form the master cylinder. The braking system is designed to remain closed. The ONLY reasons to add brake fluid is if there is a leak or if you are totally replacing the fluid. There is no need to bleed the brakes when changing pads unless the system is leaking fluid or air has gotten in the system. |
Originally Posted by ken99
(Post 14292)
Because all the components you listed (ABS, ESC, the brake light switch) as well as the Traction Control System are all integral to the brake system on the car. Iinternal diagnostics on the brake system determined the switch was malfunctioning, which tripped an error code that lit up the ABS and ESC lights on the dash.
I agree with you that the ABS, ESC are integral to the brake system. But come on, the cheap ass brake light switch? That is what I meant. And I have to wonder how many people have paid big $$$ for repairs when all that is wrong is a cheap switch? It reminds me of the old Aerostar van I once owned. The horn stopped working. Needed to get it inspected. Can't pass inspection without a horn. Went to the Ford dealer. Bad airbag sensor. Cost several hundred to repair. How is the horn and airbag system tied together? They are not. Just a crappy way to design a car. |
I agree with you that the ABS, ESC are integral to the brake system. But come on, the cheap ass brake light switch? [IMG]local://upfiles/4972/FE371C06B59C4CF685914857A32C5E38.jpg[/IMG] |
To Ken99,
I never said the "cheap ass brake switch" had nothing to do with the ABS, Einstein. But being you are a "SuperMember" complete with cape and tights, I will bow to your arrogance, and your way too detailed knowledge.Nowshut the #%&^ up. |
ORIGINAL: kevkat2 To Ken99, I never said the "cheap ass brake switch" had nothing to do with the ABS, Einstein. But being you are a "SuperMember" complete with cape and tights, I will bow to your arrogance, and your way too detailed knowledge.Nowshut the #%&^ up. https://www.hyundaiforum.com/rules.asp [quote] Hyundai Forum - Rules Hyundai Forum membership is diverse, covering people from various countries, backgrounds, ages and experiences. Considering this diversity and to make Hyundai Forum enjoyable for the majority of our membership, we have adopted the following simple posting guidelines. 1. Vulgar language, images and other offensive material including, but not limited to, race, nudity or pornography is not tolerated here. The Hyundai Forum staff shall be the sole judges of what does and what does not violate the boards standards.[/align] 2. While debating and discussion is fine, respect your fellow enthusiasts. Being of a diverse background, members are likely to express different opinions, and while opinions may differ from yours, they are just that, opinions; and everyone is entitled to express theirs freely. We will not tolerate rudeness, insulting posts, or personal attacks. Do not flame, bother, bug, disrespect, hound or taunt ANYONE on the forums or through private messaging or chat room. If we feel a thread is getting out of hand we will close or delete it. You can/will lose your posting privileges if you continue this type of behavior.[/align] 3. "Trolls or Trolling", "Flames" and/or "Board Wars" are not tolerated here or elsewhere. Posts that taunt or are otherwise inflammatory against other sites will be removed. Also, anyone found to be making inflammatory posts and remarks on other forums (starting Flame/Board Wars) can and will loose their posting privileges here. This rule also applies to those that, for whatever reason, feel a need to post negative remarks about this site on other forums. If you do, don't expect to be welcome here.[/align] 4. Double posting is not allowed and can result in the deletion of one or both posts. Double posting is defined as posting the same information in two or more separate forums. We understand that some topics might fit into more than one forum. Please try to pick the best one. In addition, please do not post in the same thread back to back (another version of double posting), if you have something more to add, edit your post, don't post twice in a row in a thread.[/align] 5. Selling or solicitation of ANYTHING in the general forum, by Private Message or in Chat is considered Spam and is not allowed. Anyone found posting excessive links to their websites, or suspected of "sneaky" advertising will be warned and will possibly lose their posting privileges. Please post your private party ads in the Hyundai Forum Classifieds forum sections. If you are a business and have a product or service that would be of interest to our members, visit our Advertising/Sponsorship page to learn how you can join our team and help support our community. We offer a variety of low-cost packages that can be of great benefit to your company.[/align] 6. [font=verdana]Please refrain from posting meaningless threads, one word (or short), "smiley" only, non-sense posts and such. Multiple or repeated posting in order to increase your post count ("post whoring") is frowned upon. If you do engage in this type of activ |
Actually it is recomended every 2 years that you flush the old brake fluid out because it can carry alot of water, remember brake fluid gets hot, gets moisture in it and brakes down. If I got my brakes done I would hope they would bleed it a little.
ORIGINAL: NovaResource Also, as the pads wear, less brake fluid returns to the master cylinder. So when the master cylinder is low on fluid, it's a good indication that the pads are worn. DO NOT ADD FLUID! Check the pads first and replace any worn pads. If you add fluid first and then try to replace the pads, you will have to remove fluid form the master cylinder. The braking system is designed to remain closed. The ONLY reasons to add brake fluid is if there is a leak or if you are totally replacing the fluid. There is no need to bleed the brakes when changing pads unless the system is leaking fluid or air has gotten in the system. |
ORIGINAL: itsthebigb19 Actually it is recomended every 2 years that you flush the old brake fluid out because it can carry alot of water, remember brake fluid gets hot, gets moisture in it and brakes down. If I got my brakes done I would hope they would bleed it a little. |
| All times are GMT -5. The time now is 05:43 AM. |
