Azera & Sonata wheels interchangable ?
I saw a set of 16 inch Azera wheels and was wondering if they'd fit my 08 Sonata.. TIA....
RE: Azera & Sonata wheels interchangable ?
Quick answer, yes. Double check to make sure they are 16x7 with a 5-114 bolt pattern. I think the offset should be ~40 mm.
No problem, they will easily fit. Bothare 16x6.5" in size and have the same 5x114mm bolt pattern.
The Sonata wheel has a 46mm offset while the Azera has a have a 38.5mm offset. That's minor andshould cause no problems at all as long as you keep the stock tire size. Each wheel will stick out about 8mm more (1/3 of an inch). |
| All times are GMT -5. The time now is 03:27 AM. |
