| wheredoesthisgo |
Nov 20, 2007 08:02 PM |
Balance shaft alignment plug
Hello friends. I am doing a timing belt on my 1995 Hyundai Sonata with a 4 cyl. 2.0 Liter. It was done about 30,000 miles ago and ran rough from day 1. Recently my water pump started leaking so I am doing this one myself and the directions say if you do not have the balance shaft lined up correctly it will cause a vibration. The repair manual just says the alignment plug is on the left side of the block and has an ambiguose picture. Can anyone be more specific. I found some info on the net that says it behind the exhaust manifold but that was on a v 6. I see a hole up there with a set screw in it but do not want to tear the exhaust apart if thats not it. Is the plug in the same spot as the v 6? Thanks for any help. Oh yeah ps. The balance shaft belt looks like it was never changed but I would like to check the alignment anyhow.
