Blower motor access shield
Hi
How do you remove the access shield under the glove box to access the blower motor on a 2002 hyundai Sonata sedan?-any help/direction appreciated. I need to remove this to inspect/replace/clean out the blower motor/cage-the fasr rhe blower speed is the louder the low hum/vibration is-I was told many times this is dirt in the cage, but I may just end up replacing the entire motor. |
Have you ever replaced the cabin air filter? That should protect the blower motor from dirt.
COMPONENTS (EVAP. AND BLOWER UNIT) https://www.hyundaitechinfo.com/data...G/eqac039a.gif The blower should just unbolt from the bottom. |
| All times are GMT -5. The time now is 07:04 AM. |
