A/C not draining...??
Hi, I have a 2008 Sonata..
I recently started hearing sloshing sounds from the passenger side. I realized today that my A/C wasn't draining even after 45 mins of driving with the a/c on. Then just now, water began leaking into the passenger side from under the glove box. Has any else had this problem? Is there anything I can do on my own since I may not be able to get the car up to the mechanic for another week or so? thanks |
Find the drain hose and carefully knock out the clog... bee/spider likely built nest that has the rubber tube clogged..
Neighbor got air compressor and blow nozzle, that all I do, reach up with nozzle, hit it with some air and hopefully be out way when the water flows out like garden hose. Afraid to do it yourself, hit any kind of auto shop and ask if they will put car up real quick and clear the drain tube. Happens to alot of cars, critters find someplace to call home. |
