CAm sensor problem for 2000 sonata v-6 2.5L
p0340 Camshaft sensor
p0707 Again the camshaft code problem was on for last year or so. New problem that started less then a week ago. the car accelerates fine . It steadily goes up when pressing on gas. But when i left my foot and hit the gas peddle again, the car either jumps or rpm meter jumps. For example at 2000rmp then goes to 3000rpm and jumps back to 2000rmp then steady goes up. First dealer had weird codes and he said it must be transmission but he was guessing from the drive in my opinion. The second diagnostic tech- did not think its transmission. He drove the car and still did not think its transmission. He suspects its the cam Sensor. I had mechanics change the cam sensor. Big problem now. The engine seems to over running. it has terrible acceleration at around 25 mph. But when high speed it flies. I have never seen it with so much power. It seems like it is stock at at a gear and struggling in low speeds. Whats wrong? this is new issue it seems?. Faulty cam I installed? dont know? I am so worried. Thanks. |
plus the the big knob cylinder on the cam looked different then the one on my car. Also the sequence on this was 110 last three digits and mine was 100. but the part dealers said it fits my car.
