crank but wont start
i hav a 2000 hyundai sonata v6 2.5 tha only cranks but dosent start.. theres is no power to the fuel pump, there is no spark and fuse #4 that is for the fuel injector dosent have any power as well.. can this be the crankshaft sensor or the pcm.. any help will be apreciated
Most likely the crankshaft position sensor. If you try starting the car a few more times, an error code will likely be generated and the check engine light will come on. Extracting and deciphering the code will confirm or deny the diagnosis.
tasseltrader
Mar 23, 2015 05:22 AM
