Cylinder miss. I can’t figure it out.
I have a 02 sonata 2.7L v-6.
the car just had the heads completely rebuilt, new timing belt and all. When the car first starts it has a bit of a rough idle then soon after becomes a miss, the miss is on cylinder 5 and 6 but was told it first started at 2 and 3. Cylinder 5 miss goes and comes I get cylinder 6 every time. While driving the car for about 45 mins it has power after that it falls flat and no power. I’ve moved cylinder 6 plug to 4 still miss on 6. I moved the injector and still on cylinder 6. I removed the exhaust and looking into the cats the front one was clean. The back cat was glowing red inside. Any help would be greatly appreciated! |
The glowing red is due to the converter attempting to clean up a very rich exhaust.
The first thing I would suggest is a compression check so we know if the timing is on the money. |
So I ran a quick compression test on the front 3 cylinders and I got 60 psi on 2, 50 psi on 4 and, 55 psi on cylinder 6. I’m gonna pull the timing covers off and verify timing.
