Dash removal to put new cd player in a 2001 sonata
I looked and search and coulnt find anything that talked about how to remove a dash for a 2001 sonata.The cd player works when the cd is hot but when its cold it dosent so any information on how to remove the dash would be appreciated.
thanks dan |
RE: Dash removal to put new cd player in a 2001 sonata
I looked and search and coulnt find anything that talked about how to remove a dash for a 2001 sonata. AUDIO UNIT[/align] a.Disconnect battery negative terminal.[/align] b.Remove the console switch.[/align] http://www.hmaservice.com/data/Passe...G/esa9035a.gif c.Remove center facia panel and disconnect air temperature switch connector.[/align] http://www.hmaservice.com/data/Passe...G/esa9040f.gif d.Unscrew the audio mounting screws and remove the audio assembly from the mounting bracket.[/align] http://www.hmaservice.com/data/Passe...G/esa9040g.gif e.Installation is the reverse order of preceding steps.[/align] |
