dreaded p0011 on 2011 Hyundai Sonata SE, new cam sensor, new oil control valve sensor
Old 11-01-2018, 10:16 PM
Michael Onofre's Avatar
Default dreaded p0011 on 2011 Hyundai Sonata SE, new cam sensor, new oil control valve sensor
Well, I have been kinda stumped on this one guys, i'm hoping one of you have some more ideas for me, because I'm just about out of ideas.
Vehicle Info: 2011 Hyundai Sonata SE
Miles: 140,xxx
Error Codes: P0011
Parts Replaced So Far: Oil Control Valve, Cam Shaft Position Sensor, Did an Oil Change/Filter Change.
Problems: Check Engine Light is one.
However, the car drives ABSOLUTELY FINE. If I clear the code on an OBD scanner it just comes back after I start driving it. I can however let the car sit and idle for hours, and the check engine light will next come on.
I went and did the oil change because the oil was kinda old. Anyone have any other suggestions?
Old 11-02-2018, 06:28 AM
allegretto's Avatar
It could be an electrical fault. If there is no power going to the OCV it will not change the valve timing and thus be out of range as soon as you rev higher than idle.
Inspect , clean and test the wires and connectors going to the OCV.
Good luck!
Old 03-23-2019, 10:59 AM
Nicole Garrison's Avatar
[QUOTE=Michael Onofre;55108]Well, I have been kinda stumped on this one guys, i'm hoping one of you have some more ideas for me, because I'm just about out of ideas.
Miles: 140,xxx
Error Codes: P0011
I went and did the oil change because the oil was kinda old. Anyone have any other suggestions?[/QUOTe
There was a recall on 2011 and 2012 hyundai sonata for metal debris that was left in the engine during the manufacturing process. You can check your vin#, the link is below. Or call your nearest Hyundai dealership and speak with someone in the service department. It probably hasn't happened yet but you will start hearing a knocking sound coming from your engine. I hope this helps.
https://autoservice.hyundaiusa.com/Campaign132/MicroSiteTemplate/MicroSiteTemplateVINValidate/1524
subzero
03-18-2016 12:59 PM
hnghodsi
01-04-2013 05:58 PM
justint420
10-18-2011 07:00 AM
reever
11-15-2010 12:37 PM
bj_otto
09-01-2010 03:12 PM
Quick Reply: dreaded p0011 on 2011 Hyundai Sonata SE, new cam sensor, new oil control valve sensor
