frt. turn signal
07 Sonata frt. turn signal has rapid blink on dashboard and weak light effect when looked at. Bulb has been changed 2x-just in case 1 batch bad- and no improvement. Could it be the socket assembly causing problem? This socket does not have wire harness like other bulb ports in headlamp assembly.:confused:
