Gearbox Oil Change Question ??
Hi, I have a 98 Sonata (Manual)
Want to drain and refill the gearbox. Can someone kindly explain just where the drain and refill plugs are? I have looked under the car and all I can see is a large (24mm) bolt or plug right at the back - is this the drain? It's damn hard to get to and won't take a socket as its too close to the frame. Is the fill plug the one on the small steel plate right at the front. Looking at it I can't see how it can hold 2.5 litres if these the correct plugs. Any help much appreciated. (Don't have a service manual - just a CD - not much help) Sonny |
RE: Gearbox Oil Change Question ??
I have a 2000 Hyundai Accent, 5 speed standard. Reverse is completely gone. should I add oil to the gear box? how do I do that?
If reverse is "completely gone", adding oil will not fix your problem. Take it to a transmission mechanic.
Also, if you have an Accent, why did you post this question in a Sonata forum? Plus, there is no need to post the same question 4 times in 4 different forums. |
| All times are GMT -5. The time now is 02:01 AM. |
